I have a couple of these:
http://www.toolfetch.com/dry-concrete-core-bits.shtml
You can find them at several different places. You really have to be careful and slow in cured concrete or the teeth will be gone in no time.
For green concrete or block, it will cut like butter. Brick is a little slower cutting. I use these for drilling nice looking holes for conduit, also for gas log, range, and dryer vents. the nice thing here is no chipout on the other side like a percussion bit. Nothing worse than having a crappy looking hole on a nice brick wall, and trying to explain why the brick or mortar is cracked or missing past the light cover. HVAC people seem to be the worst about beating a hole through a brick wall, then making a 10X10 cover plate for a 4.5" hole, or using a tube or two of caulking...
