Rayl82
- Chandler AZ. 85225
Good read thank you.Ray, please see this post. Welcome to the forum.
Sent from my HTC One M9 using Tapatalk
Power is always going to take the fastest thought to ground. That's why if you insulate yourself from ground properly you can tuch individual live conductors with no repercussions.... The case ground and ground to windings are generally the same and by adding the ground rod you've effectively created a shorter path to ground. And the breaker doesn't see it so it trips as if there were a problem.
Yes I did open the link and I thanked him for the info. We are always learning.. I tried to edit my posting or even remove it, but was unable to do so. I was assuming that like a arc fault breaker the natural return is monitored by the breaker and when a closer ground path is made the breaker trips. Not to say that is the complete reason the system described is faulting. There is probably still an issue with the circuit like missing wires in the original installation.Ray, hopefully you did open the link that George Stolz posted in response to your misunderstanding/confusion regarding the difference between earth grounding and equipment bonding. Not to pile it on here, but it is absolutely essential that all personnel who will be servicing electrical systems (especially those under 600 volts) understand that the gec (grounding electrode conductor) and the egc (equipment grounding conductor) are two totally different things and perform vastly different functions. The gec (in most cases a ground rod) does NOT provide shock protection when exposed metal parts become energized because all current (including fault current) is always trying to find the the least resistant path back to the source (poco tranny) and the earth is NOT suitable as such a path. Ground rods are for the most part useless and the only plausible benefit one might get from a ground rod would be from lightning/and or power surges (think tree falls on primary-primary hits secondary etc.) and even then its only a sometimes thing. The egc on the other hand, is meant to provide protection against exposed metal parts which may become energized as it is bonded to the source through the service neutral, which is of course a direct connection between those egcs and the poco tranny. The earth isn't a good return path for fault current because it almost always is too resistant. Lets assume you have 10 ohms of resistance between an unbonded standard 8'ground rod and the source- doesn't sound like much does it. Now apply 120 to the rod-120 vac / 10 ohms= 12 amps- not enough to trip even a 15 amp ocpd. Now think 120 vac to that egc bonded to that service neutral which in many cases will an ohm or less- 120 vac/ 1 ohm=120 amps-more than enough to quickly trip that same ocpd. Sorry for the long windedness, but grounding and bonding is one of the most misunderstood aspects of our trade, and one that has gotten people hurt and killed.
Not sure why this didn't post last night. But thank you for the information, it is a good read.Ray, hopefully you did open the link that George Stolz posted in response to your misunderstanding/confusion regarding the difference between earth grounding and equipment bonding. Not to pile it on here, but it is absolutely essential that all personnel who will be servicing electrical systems (especially those under 600 volts) understand that the gec (grounding electrode conductor) and the egc (equipment grounding conductor) are two totally different things and perform vastly different functions. The gec (in most cases a ground rod) does NOT provide shock protection when exposed metal parts become energized because all current (including fault current) is always trying to find the the least resistant path back to the source (poco tranny) and the earth is NOT suitable as such a path. Ground rods are for the most part useless and the only plausible benefit one might get from a ground rod would be from lightning/and or power surges (think tree falls on primary-primary hits secondary etc.) and even then its only a sometimes thing. The egc on the other hand, is meant to provide protection against exposed metal parts which may become energized as it is bonded to the source through the service neutral, which is of course a direct connection between those egcs and the poco tranny. The earth isn't a good return path for fault current because it almost always is too resistant. Lets assume you have 10 ohms of resistance between an unbonded standard 8'ground rod and the source- doesn't sound like much does it. Now apply 120 to the rod-120 vac / 10 ohms= 12 amps- not enough to trip even a 15 amp ocpd. Now think 120 vac to that egc bonded to that service neutral which in many cases will an ohm or less- 120 vac/ 1 ohm=120 amps-more than enough to quickly trip that same ocpd. Sorry for the long windedness, but grounding and bonding is one of the most misunderstood aspects of our trade, and one that has gotten people hurt and killed.
