panhandle444
- oklahoma
Can someone provide literature on the proper amount of rubber tape that should be used on a burndy?
:blink: Hmmm... the exact same article I posted a link to earlier.Here is an ECM web page that addresses a few things for tape applications: http://ecmweb.com/content/electrical-taping-skills-lost-art
Here is a pdf of the same article: https://multimedia.3m.com/mws/media/374996O/ec-m-tape-article.pdf
A Burndy? Rubber tape?It's been said a million times before, but if you are still using those methods, you are living in the stone age. It's time to get up to speed with Polaris connectors, Ilsco Clear Taps, or whatever brand you prefer. Heck, even Burndy makes their own version of them.
Should have been more specific. I basically was looking for the amount of tape that should be used when making repairs or connections. The article on "taping a lost art" was very informative.Burndy what? They have a pretty big line of products. Though I'd guess you need to look more into the tape manufacturer to determine how much tape to use for a particular application.
Cambric tape is used to make a splice more durable/soften sharp corners, but also keep the rubber tape from melting into mechanical connections making them easier to get apart latervarnished cambric tape is just used because it makes a splice more durable and is more resistant to environmental factors?
There is such a thing as friction tape. Some old timers used it for connector wrap, but that's not what it is for....
My boss always called it "friction tape" but I realize it was "cambric" now.
Post looking at some images, it was indeed cambric tape which he called "friction" tape.
Are polaris (or similar) connectors listed for wet locations? i.e. parking lot light ground boxes or is there a scotchkote like product to wp them?
The "standard" Polaris connectors are not, but there are other types that are - they have a "boot" for each conductor port that seals around the conductor. Some you must use a specific conductor size to get proper seal, others you trim the "boot" for the conductor being used.
Depending on the type - you might have to use all ports in order to keep the entire assembly "sealed"
Thanks kwired!
Apologies to the OP, if this wasn't apropos for the original topic.
Cambric tape is used to make a splice more durable/soften sharp corners, but also keep the rubber tape from melting into mechanical connections making them easier to get apart later![]()
