Suppose you have a feeder originating in a sub station that is 480volt 3ph 4wire, a 300ft run but there was never a ground wire pulled into the conduit with it. Which I know is not to code and if it were a new install, a ground would be pulled in as required. Say you absolutely do not have the time and resources at the time to pull the feeders out and pull back in to get a ground wire back to the substation. But there is 2 spare empty conduits that go back to the substation. How would you get a ground back to the substation in order to get it grounded safely without pulling the wires out of the conduit and with minimal downtime? Of course the plan would be to pull the feeder out and back in with a ground when time permits.
