The contractor is suggesting the use of HDPE in lieu of PVC, to go across a path of the parking lot in a project we are working on. He mentioned not using the PVC conduit under the ground , so he doesn't need to saw cut.
Should I have any concern? how does it transition from conduit to HDPE and back to conduit?, please let me know what you think.
Thanks
this is what he wrote:
To prevent sawing and cutting of paving, the electrician intends to use directional boring method to run the feeder from Genset to the transfer Switch. Please confirm the use of HDPE for conduit in lieu of PVC is acceptable.
Thanks
