quiet_canuck
Hi, I was just wondering if anyone had any tips on running emt straight. I measure the best I can but the pipe still gets wavey. Thanks.
Pipe usually comes from the supply house somewhat bowed. I try to turn the bow up or out of sight.
I'm running the pipe on a drywalled ceiling. Runs are no more than 100'.
I was wondering the quickest way to run straight pipe. Id appreciate if you went into detail, say u start out of a box. Thanks.
What's the fast way to run straight pipe. In detail if its not too much trouble, thanks.
I'm old school I guess. I just use a measuring tape and a level. I use the
bowed pieces of EMT for ceiling spaces. One tip I can give you is
when the weight of the EMT starts throwing the run off level, add
more straps or supports. 24" levels are a great help for a straight run
as well.
If you do snap a chalk line make sure you use only blue chalk. Per the labels on the chalk containers, there is no known way to remove red or yellow chalk.If you don't have a laser then I would snap a chalk line on the ceiling and use that as a guide. If running more than one pipe adjacent to each other use the first straight one run with the line as a guide for the rest.
