When running an grounding electrode conductor in order to bond (2) grounding electrodes (DC and AC electrode) can the grounding electrode conductor be run with the phase conductors and equipment ground conductor running between two pieces of equipment.
For instance in a PV system if there is an inverter at one location with a DC grounding electrode and an AC panel at another location with an AC grounding electrode and the electrodes are being bonded together with a grounding electrode bonding conductor can this grounding electrode bonding conductor be routed with the phase conductors and equipment ground conductors running between the inverter and panel?
