MagicMikey
New User
- Canada
- Electric Mechanic
Hello, my sheds subpanel currently does not have a neutral wire. Right now, there’s an 8/2 cable from a 40A breaker in my main panel going to the subpanel in the shed that is powering my pool pump at 220VAC on a 15A breaker.
I want to add some receptacles and lights to run off of 120VAC but there’s no neutral in the subpanel. I know that the best way might be to replace the 8/2 cable with an 8/3 but that is very costly.
I would prefer to run another cable, perhaps 10/2 simply for the neutral wire. The subpanel will have only two 15A breakers running off the 120VAC, hence the smaller gauge.
Would this be an issue?
Thanks.
Thanks.
