I took this pic recently of an overhead high voltage (I believe 13kv line to line, 7kv line to ground) transition from an overhead local distribution to under ground feeder. The conduit was under pressure from what I think was a break in the conduit upstream that allowed water under gravity pressure to transit the line and exit at the transfer box at the bottom of the pole.
It seemed to me that this was a dangerous situation since moving water under pressure in conduit might be able to wear away the insulation or thru vibration, etc. cause the line to make ground. Step potential would then be a concern.
I ask a local about this and he said this situation has been going on for years. There is a walking path within 3 feet of this transition box with many people including young children passing by every day.
Not sure if the POCO is aware.
