wireman3736
- Vermont/Mass.
I'm going to be getting involved in an RV project in the spring that was partially done by another electrician, One section was already done and I see they fed them with 3 wire but some they pulled a separate bare copper ground wire with the three insulated aluminum conductors, also I don't see any ground rods at the pedestals. I have read the code but I'm still a little confused on the grounding,
1st do you have to use 4 wire, 2nd does the equipment ground have to be insulated, 3rd am I required to drive ground rods and 4th if I drive ground rods am I required to use a grounding conductor from the main panel or can I use 3 conductor then bond my ground and neutral at the pedestal per 250.32 (b) 2. My opinion is that I have to use 4 wire all insulated and I am required to install a GES at each pedestal. Seeing what others have done here though I want to have my facts straight when I talk to the park owner.
Looking for opinions.:-?
