sliderule
- Langley, BC
For anyone here who may own an RV and reads RV forums they would know that quality control is a significant issue in the RV industry. I know we have definitely had our share of issues on our RV and one we previously owned even got replaced by the factory under warranty due to some serious issues.
I was replacing an SCD receptacle on the weekend simply to change it's color. What I found, to me at least, is quite bothersome. As can be seen in the first photo, the hots and neutrals are only pushed onto one of the terminals instead of two resulting in the receptacle only being able to carry 1/2 it's 15 amp rating. Also, the jacket doesn't extend into the device as required. The 2nd photo is from a previous RV we owned and is another brand and in that one, a hot conductor is also not pushed into both terminals. The terminal is damaged and it appears as if they used a screwdriver or pliers instead of the correct tool to push the wires in. I also previously found two receptacles with reverse polarity and a completely loose wire at a breaker in our current RV and issues with the 12 VDC system (both RVs mentioned here were bought new).
The NEC has an entire article covering electrical requirements for RVs and RV parks. That is great but the RV manufacturers do not have licensed electricians on staff or an inspection process in place. There are no PEs or government electrical inspectors that inspect the work and there is no agency to file a complaint with. With no oversight, there is no incentive to do work correctly and the manufacturers don't have to worry about repercussions and bad or sub-standard work happens as a result.
Is there a fundamental problem with the way the RV industry is in regards to electrical work? Is there anything that can or should be done when you find something of concern? Who would a person contact anyway? RVs are built in one state and shipped all over the US and to Canada so which jurisdiction could or would be responsible? Between what happens with RVs and also RV parks, I can't believe the things I've learned and it's so unlike the way things work in the construction industry. If I am finding the problems I have, they can't be unique to our RV.
Thanks!
Thanks!
