petersonra
- Northern illinois
- Semi-retired engineer
You might be better off putting the lower voltage transformer over by the new loads.
Not this one ..
I'm trying to eliminate having a 60 A 120 v panel if possible.
The neutral for a 120/240V output would be provided at the X2,X3 connection. It would need to be bonded to the EGC and connected to a GES.
I did plan on that as well, although I changed up my game plan with eliminating a closer 3 phase 277/480 source and go with the undersized 120/240 system 40' further. As noted on my drawing below.You might be better off putting the lower voltage transformer over by the new loads.
I could, although Id still need the buck boost transformers I believe, because the stepped down voltage will still drop down below a safe level after 300-400 ft. its a tough call on which scenario really is more cost effective.Why wouldn't you just connect X2 and X3 and then ground them? X2-X3 would be your neutral point.
