Are there heavy wall non-metallic fittings available, such as LB's, that are specifically designed for use with Sch 80 RNC?
Also, would using a PVC primer/cleaner, such as plumber?s use on DWV pipe, before applying PVC cement, violate the listing of the RNC or fittings?
I can?t see how, but haven?t seen any reference to using it in manufactures spec sheets or installation instructions.
TKX
TKX
