- Placerville, CA, USA
- Retired PV System Designer
Sanded, as in roughened the surface, or as in trued up the ends to bottom out uniformly in the fittings?I have rarely ever worked with Schedule 80 but helped a coworker make a sign frame with it. Rectangular frame used to hang a banner. Pipe, & sharp 90 plumbing elbows. He sanded the pipe ends and used pipe cleaner on them, then glue, but put no glue in the elbows. I was trained to put glue on both surfaces and have always done this. But he has made a lot of these frames and they have been holding up for a few years. I never sanded PVC either, new to me.
How do any of you glue Schedule 80?
When using primer with solvent glue the surface roughness is not really significant to the joint strength.
Among other things, Schedule 80 is used for plumbing at higher pressures, and to get a suitably strong joint primer/cleaner must be used.
