James L
- Kansas Cty, Mo, USA
- Electrician
Wondering if anyone knows anything about
I got a call today to go add a receptacle for this icemaker, which I did. It's at a basement wet bar which has 4 countertop receptacles on a 20 amp circuit. So I added this onto that circuit.
Then I got a second call to ask if I ran a dedicated circuit, to which I replied "no"
I was asked - doesn't it need a dedicated circuit?
I replied that I've never seen an under counter icemaker draw more than 3 or 4 amps, but that I would look into it.
Well, looking at the data sheet shows that it uses 14.4 kw for every 100 pounds of ice.
Huh?
So I called the manufacturer and their goofy tech support gave me more nonsense. He said it draws 8.22 kw every 24 hours
I asked him does it run constantly or does it cycle on and off. He said it cycles, because it's not running all the time if the ice is full
duh.
I then asked him how much amperage would I read with an amp meter. He said he doesn't know. Good grief.
Anybody know about this unit?
I may just go run the circuit, but it's 50 minutes each way. Not my preference.
Scotsman CU50GA-1 50Lb. Gourmet Cube Undercounter Ice Machine
