Isn't it the same as the ones that hold the cover on? If so, take one to a hardware store and match it. It's been years, but I had to do that once and I found a replacement at Home Depot.Does anybody know what size screw that holds the turn on switch for the sma disconnect, I lost it , I looked on line no luck thanks
No its the one that turns off and on the disconnect, the on off switch just spins if you don't have the little screw, it only comes with one , so I have nothing to match it to thanksIsn't it the same as the ones that hold the cover on? If so, take one to a hardware store and match it. It's been years, but I had to do that once and I found a replacement at Home Depot.
It's probably metric, so this will likely be a McMaster order, rather than something you could expect to find at a regular hardware store. I know that most cover screws for SMA inverters are M6 socket head cap screws, so I expect metric for everything else.
Which exact SMA inverter are you talking about? The Sunny Boy series? Or the Tripower series? Or other? I'll check the Sunny Boy disconnect, and let you know.
I have found those socket screws at HD, but the OP says it's not one of those but the long skinny one that clocks the shaft of the rotary switch that runs the disco to the plastic knob.It's probably metric, so this will likely be a McMaster order, rather than something you could expect to find at a regular hardware store. I know that most cover screws for SMA inverters are M6 socket head cap screws, so I expect metric for everything else.
Found it, it was #4-40 they also had it in stainless steel at homedepote ������
