I'd like some opinions. Existing SEU cable (#2 Al) runs up a wall, then under the eve of garage, then up through a small roof overhang (roof is about 16" deep) using a nipple through the roof vertically, then cable continues up the wall to the weatherhead.
I need to replace the existing cable, but the eves are covered with aluminum soffit. I also don't think that it's a good idea to let the nipple end inside the soffit. I would like to use a nipple all the way through the roof and soffit (nipple would be about 18" long) and run the cable on the underside of the soffit, exposed. This would also permit the nipple to drain and get the cable out of the enclosed eve.
Anyway, just wondering if there would be any problem as far as the code is concerned with this arrangement? I cannot find anything that doesn't permit this, but I thought I'd check with some of you who may have done this, or some of our inspectors here on whether they've seen this done.
Thanks for the input.
John
John
