w hen using pvc on a outdoor service as a complete system to the weather head can se cable be used inside the conduit maybe 15 feet?
Not necessary if you strip the sheath, right?How will you meet the fastening requirements ?
Added: The conductors must be marked, right?
If you mean running a pipe to a weatherhead then it's a service mast. Usually it's 2" rigid metal conduit. Check your local codes and the power companies requirements.
