Re: SE Cable
I'm on a roll!!
This is pretty interesting. The NEC is a consensus document, NY's is not. I was searching the NYS website for info, and this is one item I found.
If you would like to discuss this at a meeting with them, they say there is some kind of meeting twice a month, great!! I found the schedule and location for the meetings. The meetings were discontinued in 2000. That is 2 years before the document became law, interesting.
I will say one thing in favor of NY. If you call the State office, you will get a live person and in most instances they will give you an unofficial answer. If you need an interpretation, it could take 30 days.
HEE! HEE! a couple of more tidbits. Required switch locations, pool requirements, fixture locations, foot candle requirements for fixtures. These and more are covered in NY.
Wait thought all you had to do was read it?
There are times when you use the NYS Residential Building Code, and there are times when you have to determine when to use the '99 NEC. This is covered in the scope of the Residential Code. Some guys are very frustrated trying to figure out these requirements.
There is one way around most of this mess. Remember codes are minimum requirements, go beyond the minimum and you will cover your behind 'MOST' of the time. But... what about bidding work?
And you wanted to be an electrician.
There is a 'silver lining' to this cloud, which I will discuss at another time.
Pierre
