OK I'm confused I want to run a 200 amp main breaker to a 200 amp sub panel residential what size wire xhhw do i need 2008 Nec
In my opinion, the wording of the NEC states that if the feeder feeds the entire load of the dwelling then 4/0 ser would suffice. Thus T.310.15.(B)(6) is allowed even with ser on the inside of the home.
If this feeder did not feed the entire load then, IMO, you would need 300 KCM as long as the calculated load was 190 amps or less. Now try and get the 300 KCM under your resi panel lugs (most are only rated for 250KCM) and I don't believe you can even buy SER that size.
Around here they have also dropped to 150 amps but some areas are allowing 250KCM for 200 amps.
Another method is to pipe your feeder. That's what I do.
