Sealing locknut required?
qcroanoke
Sometimes I don't know if I'm the boxer or the bag
Roanoke, VA.
Sorta retired........
I have a 200 amp power inlet mounted on the exterior of a building. This inlet has a two inch threaded hub in the top. If I go out of the top with two inch rigid am I required "by code" to use a sealing locknut on this?
No. make it up wrench tight and if you are concerned about water drill a 1/4" weep hole in the bottom of the inlet
