I've been asked to help my church install 4 circuits to outside receptacles from a 208y 120 3 phase panel. Being on the residential side I haven't been in a 3 phase panel in 15 years and I'm second guessing myself thinking there's a big "duh" issue I'm missing, double check me here.
Plan is to have four single pole 20 breakers, running 3/4 conduit 30" penetrating wall into weatherproof boxes with gfci's and bubble covers pulling four 12ga hots four neutrals and a ground.
Seems pretty straight forward but I'm getting myself hung up on the 3ph.
Another question is if I used gfci breakers could I feed each receptacle with two circuits splitting the yoke hot and neutral having two duplex receptacles and four circuits? I know residentially I'd have to use 2p breakers and a mwbc but wouldn't want that here. Thoughts
PA 2014 nec
PA 2014 nec
