Yes I did the job by myself, It was a race against day light.Nice work. Did you get this done in 2 hrs by yourself? If yes, you have some pretty quick hands. The $600 for the meter pan and overhead service conductors is right on the money (could be even more depending on the lenght, Al or CU, SEU or conduit)The other charges $150 for hook-up-yup we charge $200, $155 emergency response fee (Ok, amortize that over the trip time and the actual work time probably about $50/hr premium..OK for ER work)Sounds right to me. There is tremoundous value in what you able to do. The quick response time has value as well. You can't get this type of service for cheap! BTW, what to do you use to connect the lines at the point of attachment?
jj, I tried to find a website or picture for you but had no luck. A Fargo (Trade term) or a Farga (the actual part name) is a two sided parallel clamp with one bolt head to use a socket for clamping. The service cable inserts in one end and the utility feed in from the other end. The cables lay side by side with a divider. The clamp is made up of all metal and requires a "Fargo Cover" that is made out of plastic. For a single phase service it would require 3 "Fargo's" 2 for the hot and one for the neutral. They come in different sizes depending on the service size or your wire size.I am not familiar with Fargo's. What are they?
How much do you charge to do a 200 amp service change???Originally posted by apauling:
still not willing to do the actual cost??
Fargo Manufacturing Company
Fargo Manufacturing Company is a manufacturer of distribution and transmission products, principally for the utility industry. Fargo's distribution products include electrical connectors, line splices, dead ends, hot line taps, formed wire products, wildlife protectors, and various associated products, and its transmission products include splices, sleeves, connectors, dead ends, spacers and dampers. Fargo's products also consist of original equipment and resale products including substation fittings for cable, tube and bus as well as underground enclosures, wrenches, hydraulic pumps and presses, and coatings.
Why does a real-estate salesperson make $20000 on a house sale that required 3hrs of work?i was trying to figure if he was actually getting $400 an hour or not, of course, not including driving time.
[QB]but I was a contractor,
paul
so that explains it. I used to do things for what I thought would be a good price. Than I had to starting pricing as if I wanted to stay in business.
