i would like to know if i can use a 100 amp panel with 100 amp double breaker as a secondary panel the neutrals connected to neutral bus, and the grounds connected to the ground bus,the cable feedind this panel is a #2aluminum,wire going to a 100 amp branch circuit double breaker in main panel which is 200 amps.
