mbrooke
Batteries Included
- United States
- Technician
Brain freeze. How do I convert seconds to cycles equation wise? I have lost my proportion logic. :ashamed1:
16.67mS = 1 cycle
What basis? 60 Hz?
if you want to convert cycles/sec to sec/cycle
just invert
if f = 10 cycle/sec
time = 1/10 = 0.10 sec/cycle
if on a 60 cyc/sec basis
divide by 60
1 cycle / 60 cyc/sec = 0.01667 Sec
Thanks, thats it!
0.35 seconds / 0.01667 = 21 cycles.
The simple way is to go by what you already know. That is seconds and cycles. You know that 1 second is 60 cycles. To get from 1 to 60 mathematically, you just multiply by 60, so seconds times 60 gives you the number of cycles.
No need to do repeating decimals or division.
Seconds x 60 = cycles
Multiply by 50 if you want to get the right answer; use 60 otherwise.What if I be in Spain or Austria?
Simplest is best.Multiply by 50 if you want to get the right answer; use 60 otherwise.
mobile
mobile
Period (t) is the mathematical reciprocal of frequency (f). 1/t = f, 1/f = t
The question begs to be answered:So, if t= 1 second, then f would = 1/1, or 1?
I know what you are getting at, but as presented, the above question begs to be asked.
Yes. A frequency of one Hz has a period of one second
Not surprising at all to me.
mobile
Looking back at the exact wording of your example, the correct answer would be that if t = 1 second, then f would be 1/second or one per second. Not just 1.So, if t= 1 second, then f would = 1/1, or 1?
.2 seconds times 10 cycles per second, equals 2 cycles.
As I stated, the formulas you reacted to were just an intermediate result, not the final answer.Agreed, but there is no multiplication in these formulas:
1/t = f, 1/f = t
Your example,
.2 seconds times 10 cycles per second, equals 2 cycles,
is:
t(time) x f (cycles per second) = x (number of cycles)
not:
1/t = f, nor 1/f = t
If they were intended as a direct answer to the OP, then, yes, they were not adequate.
