Re: Securing EMT
My feeling towards this subject is that
within means just that. If you have two boxes within 3 ft of each other, then the EMT is supported within 3 ft of either end by virtue of the connector on the other end. More than 3 ft and less than 6 ft is up to the AHJ. Over 6 ft is required to have a strap.
That is the way I would enforce it if I were the AHJ. The 3 to 6 ft would be up to the installer. If the run were located in such a manner that the run was not subject to getting kicked and was secure, I would pass it without a strap. If the run was not solid, I would turn it down. Since I am no longer an AHJ, it is a moot point how I would enforce the rule.
