We are installing a 480V 1hp VFD on a 1/3hp screw conveyor. Is this an application where I should use the sensorless vector control on the drive for this motor?
If I understand correctly a constant torque load is an application where sensorless vector should be utilized on the drive. It seems to me that a screw conveyor is a constant torque load and therefore could be controlled in sensorless vector mode.
Does the fact that this motor is so small and the fact that the drive is larger than the motor not require that that sensorless vector control is used for this application?
