Is there anyone that might be able to sanity check me on a system layout I'm looking at under 2020 NEC adoption.
The property the system is on is a self storage facility with 10 separate buildings.
Each building has a different roof area so different DC Wattage ranging from 26kw to 122kw.
Each building would have its own dedicated inverter with rapid shutdown.
AC circuits from each building would go to a equipment pad with a 480V switchboard and Transformer.
12.47kv Line would go to the street.
Two items have caught my attention though, the first is the buildings will all be fed from a separate electrical service for lighting and plug loads. Since the PV circuits won't be going into the buildings I think we are okay there... The second thing is I'm unsure if we could run DC circuits from one building to another to reduce the number of inverters? I'm worried that an AHJ will want to have the rapid shutdown + disconnecting means on the buildings they are serving. I think we will need to reach out to the AHJ either way but figured I'd throw this out there. Thanks all.
