wirebender
- North Central Texas
I have to go clean up a job where they ran the electrician off.
They built a new detached garage and are moving the service to the garage and feeding the home from there with 4/0 al in 2" PVC.
They did not run an EGC. They did run empty conduits for telephone. I know that under 2005 the EGC is require in this situation.
This municipality is under the 2002NEC and I can't seem to access the free codes at NFPA anymore and I don't have a 2002 NEC.
Was an EGC required in this situation in the 2002? I think so but want to make sure before I try to re-pull the feeder.
Thanks,
Tony
Thanks,
Tony
