Greentagger
- Texas
- Master Electrician, Electrical Inspector
Would a separate building on the same concrete slab have to comply with 225.31& 225.32? Specific situation is the service for the residence has been built on the garage. The garage and house are not connected structurally other than the slab. The service at the garage is an exterior service panel board with a main breaker. From there an overcurrent protection device is used to feed a panel back to back to serve garage. Also is an overcurrent protection device which feeds the main residence MLO panel by way of an underground feeder. Is a disconnecting means required “at“ the main residence? Opinions and interpretations welcomed. Thanks.
