Gerry de Pedro
We ran 2 sets of 4 ? 300 mm. sq. cable in a cable tray as a parallel feeder for a given Main Distribution Board. The tray is right above the switchgear. The height between the switchgear and the tray is 0.6 meter AND THE TOP OF THE SWITCHGEAR TO THE TERMINAL INSIDE WHERE THE sets of the cables are to be terminated is 2.5 meters. We are to land the cables but, from the tray, can we start to join the RED phase together, the Yellow phase together, the BLUE phase together and the NEUTRAL together down to the terminal inside the switchgear in a total length of 3.1 meters as it is not mentioned in the code when to group together same phase cables? Is this a violation of the code? Would it cause induction heating for that small distance? Please explain. Thanks a lot.
