I am trying to make sense of the term "seperate building".
Im estimating a job to install a sub panel in a garage to feed outlets in the garage and future inground pool.
He wants the panel on the back wall because years from now it can feed the pool equipment on the other of the exterior wall.
The garage is back off of the house and only connected at the corners. Each building has its own exterior walls. Im making sure that I can install a 4 wire feeder in conduit (insulated egc) to this sub panel and years from now will be able to feed his pool from it. I know it says "seperate building" so I want to make sure this scenario works.
Thanks
Thanks
