aelectricalman
- KY
Re: Septic pump and alarm
Thanks for help hurk.
must be nice to have backup, try doing biz without it , then you can be in the shoes of the majority of US electricansIf the inspector doesn't enforce I'll write the state.
The other is a float switch which would be for the pump. If you also have a two conductor that runs out of the tank that just has striped ends then I would say most likely this piggy back plug is the float switch for the pump.I almost have this figured out. What are the two plugs which piggyback and plug into the 12-2 Receptacle. One is the pump motor, the other is?
