Q1. Is it required by code to have a disconnect switch within sight from a residential 120 volt submersible septic pump and float switch (controller)?
If so what about a well pump that is 200 ft below grade?
Q2. Can the low voltage conductors for the high water alarm be instaled in the same raceway with the 120 volt pump conductors?
