SER 200 A
Good question. I did a quick search and found no such item. What's the application?
Watertight connector
Thank you for the responses.
Application: sub-feed 2nd. flr. apt. 3R 200A disco.@ multimeter, enter from the side, concentric KO's.
SOOW type connectors?
I have never seen on but that does not mean squat. I would be interested in it though. Evertime I have run SER its been inside. Anytime I ran it outside its been in pipe. Will that cable be out of harms way so it does not need physical protection?
If I remember correctly, if you're entering a disconnect below the live parts you can use an SE squeeze connector.
SER
SER
Again, thanx for the responses.
Checking w/AHJ; squeeze connector, sleeve w/sealing locknut and reaming the wp connector.
Response to follow.:thumbsup:
X|
