sweetsparkette
New member
Does anyone have a quick how-to on braiding a mare's tail?  I made one about 8 years ago and not quite sure how to start.  Any help would be appreciated!
			Smart $ said:A mare's tail is using a pulling rope "braid" around wire in the middle of a pull. The pull is done simultaneously at pull points, rather than figure-eighting the wire on the floor and pulling a section at a time.
I believe you should reopen the thread![]()
A real quickie is, and I'm assuming you are using 3-strand rope, is separate a fair length of the 3 strands (depends on size of rope and size of wire). Start a 3-strand braid...Does anyone have a quick how-to on braiding a mare's tail? I made one about 8 years ago and not quite sure how to start. Any help would be appreciated!
	Wrong forum for horse grooming questions.
Is the OP refering to half hitching?
I'm a frayed knot. :grin:Is the OP refering to half hitching?
No. Half-hitching is fine for low-tension pulls (...and don't we wish all of them areIs the OP refering to half hitching?
No. Half-hitching is fine for low-tension pulls (...and don't we wish all of them are). But for high-tension pulls, most to all the tension is on the first hitch. The high amount of tension can deform, possibly even tear the insulation... which we definitely do not want to happen.
A mare's tale is just multiple unraveled strands of the pull rope braided or otherwise criss-crossed around the wire(s) so as to mimic a chinese finger puzzle effect, distributing the pull tension to a larger area of the wire insulation.
That's great. Same principle... but a kellems grip isn't always readily available, let alone a split-weave one, when you need it. On some jobs it suprises me when the contractor actually supplies the proper ropeI would use my kellems grips with the side pulling loop.![]()
No no no no no. That terrible practice is how one gets cut badly.If this is plastic rope, melt the ends of each stran to prevent fraying.
	That's great. Same principle... but a kellems grip isn't always readily available, let alone a split-weave one, when you need it. On some jobs it suprises me when the contractor actually supplies the proper rope![]()
owwwwwww
I don't see how one gets cut with a melted end. I never have. Been burned by dripping melted plastic, and not that anyone wants a kind of burn, but that kind is definitely one you don't want because the plastic sticks to your skin. The easy option is to just wrap the ends with some 33 or 88 (1700 if the big cheese is bird doggin' yaNo no no no no. That terrible practice is how one gets cut badly.
