Qwertytfc
- Arvada, Co
Per the 2017 code cycle for type se cable interior installs I understand that anything #10 or smaller in insulation must be take at the 60c column. My question is can anything that is not in insulation or is larger then #10 use the ampacity based on 75c column/terminal rating? It states excluding 334.80 but also says you can use the higher temp rating for derating as long as final ampacity does not exceed 60c column. I am confused... Is all ser for interior installs to be used like nm at 60c? Thanks in advance.
