mdshunk
- Right here.
Using anything in violation of it's listing.mpd said:marc
what rules are you talking about
All I can think of in response to that is, "so what"? How else would a fella know if he's complying with 110.3(B)? No need for a redundant code section, which I don't believe is what we're dealing with here at all.mpd said:I know what you are saying, but there are many contractors & inspectors who don't read the white book and would not know this info,
Bob, there are many rules in the Code that mirror the UL White Book just because there are so many who either do know the White Book is actually part of the Code book or do not even know that it exists. The Code Making Panels will take something from the White Book and move it into the Code just for that reason.iwire said:It seems like if it was already prohibited they would not have had to change the NEC. :grin:
charlie said:Bob, there are many rules in the Code that mirror the UL
iwire said:That is also what the instructor at my class said.
'The outside of a house is not a wet location'![]()
inspector141 said:In the 05 code article 338.10(B), there are two areas where se cable is allowed. 1. Interior 2. Exterior. If the ser cable is not identified for underground installation, I don't know how it could be allowed. Exterior and underground are two totally different installations. Also, would the ser installation be condidered a sleeve or a complete conduit system? I would not allow ser cable to be pulled in a long conduit system, inside or outside, when there are say two or three bends in the conduit. Too much tension and friction in my view.
In the 08 code, case closed. 338.12
inspector141 said:I would not allow ser cable to be pulled in a long conduit system, inside or outside, when there are say two or three bends in the conduit. Too much tension and friction in my view.
iwire said:You do not get to say no. The NEC does not prohibit it, other then in raceways underground.
Check .22 of any raceway Article.
'Cables shall be permitted to be in installed where such use is not prohibited by the respective cable Articles'.
The Article for SE does not prohibit installing SE in a raceway.
BTW, SE actually pulls very easily into raceways.
