- Lockport, IL
- Retired Electrical Engineer
My take is that the phrases "series circuit" and "parallel circuit" are intended to facilitate calculations of how voltages and currents behave when you have more than one load. My answer to Dennis' question is that the phrases have no meaning for a circuit with only one source and only one load.
- It is true that the source and the load are in series with each other, in that all the current flowing in one will also flow in the other.
- It is also true that the source and the load are in parallel with each other, in that the voltage across one will always be the same as the voltage across the other.
- But neither of these circumstances would cause the circuit to be described as either a "series circuit" or a "parallel circuit."
