Questions on series rated system:
1) What would be the advantages & disadvantages of the series rated system over full rated system?
2) Can more than 2 OCPD be used for series combination?
3) When you have your main OCPD in remote location from your branch OCPD, how this series rated system works? I mean it is very likely you will have a different available fault current at two locations. How do your upstream OCPD of series combination play a role here? Do you have to take that into consideration? Like I asked in Q#2, can you use more than 2 OCPD for series combination?
4) When your main OCPD is located in remote location in a separate enclousre, do you also have to take your conductor impedance into consideration?
5) When would you use series rated system and when would not?
Thank you for your answers.
