chicar
- Lancaster,Pa
Is there such a thing as a service after the main disconnect? I say these are feeders. Just because there are meters after the main don't make the meters a service. What is your opinion?
Jim W in Tampa said:Anything after that first disconnect seperates ground from neutral so hard to call them a service
chicar said:Is there such a thing as a service after the main disconnect?
No, the service stops at the main disconnect(s).NEC-2005, Article 100:
Service. The conductors and equipment for delivering electric energy from the serving utility to the wiring system of the premises served.
I thought this was going to be a customer relations question.chicar said:Service after the service?
If you don't drop the ball into the little box on the other side of the net you get to take a second service. But if you miss that one, it's called a double fault and everybody has to stand on one leg until the gradient dissipates :wink:charlie b said:I thought that anything after the service was a volley. At least, that is what I learned from www.wimbledon.com. :lol: :lol:
