Power Tech
- Lebec, California
Went to change a service in So Cal. Got the permit, called the Edison service planner. He will send a man to unlock the meter. I tell him it's an underground feed. If he could disconnect at the xfmr ao hand hole, and reconnect the same day. He says he will need inspection and a power release to reconnect if he disconnects. He says it will be about 3 days to get the paperwork and generate a work order. I asked him what are my options? He says contractors usuly get a lot of tape or you can get a generator (ha ha). The public gets GFCI's, AFCI's.
This process needs to be streamlined so the customer is not out of power and the contractor is not forced to work hot. What do you guys do on underground services?
Terry
Terry
