What would be the reason for having to spend 1 to 2 years working with these voltages? :-?
i was working in electrical manufacturing in 1975, doing small runs of
custom capacitors, for a company in santa fe springs, ca.
ratings on the caps were up to 35kvdc, and you hipot at 125% normally,
or 150% if mil-spec-105D was called for. so i was working at up to 55kvdc.
extensive work with megohmmeters, o-scopes, and high voltage test
racks.
i designed my own test fixtures, and safety devices, based on the tasks
at hand. using the tools i had developed, i was able to work barehanded,
so my manual dexterity wasn't compromised. i machined my own hot tongs
out of lexan, and epoxied shorting resistors inside them, so i could handle
charged capacitors while discharging them at the same time. made a foot
operated lexan shield to swing up between me and the product under test,
as they sometimes faulted in a dramatic fashion.
osha and occupational safety were virtually nonexistent. you figured out
what you had to do to remain safe, and did it.
i did it for 50 hours a week for about 2 years. no problems, no near misses,
and i learned a bunch about HV in the process. was building tesla coils in
my garage during that time, and learned about harmonics, and composite
AC.
