zemingduan
- Philadelphia,PA
- Electrical Designer
I am an electrical engineer. Recently, we got question from electricians for some projects asking if they can run service conductors along the exterior wall like on the ground or 10' above the ground before entering into the building to avoid trenching... This has hazardous and a bad idea for me. But I didn't find a NEC code section that forbid it. Which code section governs it? Any distance limitation to run service conduit along exterior wall horizontally and vertically?
We have another project that has new 4.6kv underground incoming service to an existing building. The electrical room is on the second floor. Can I run the 4.6kv underground conduit stub up to ground and vertically on exterior wall then enters to the switchgear in electrical room behind the exterior wall? Any better idea?
Thanks!
Thanks!
