zemingduan
- Philadelphia,PA
- Electrical Designer
You understand my concern exactly! And thanks for the info about the NEC 2026 Code update! I was trying to check if 2023 NEC has updated language that is clearer which turns out NEC 2023 has the same language with 2020 & 2017 RE. the fire pump supply conductors. But I didn't check the 2026 code.I was going to submit a Public Input to remove the first reference to 230.6 in section 695.6(A)(1) but the section has been revised and relocated in the 2026 code. 230.6 is no longer referenced so, no need for a PI.
Below is the screenshot of NEC 2026 for your reference. My concern was reasonable
