Re: service disconnect
Don, member #4,
If you have a panel,which says it can be used as service equipment when not more than 6 switches are installed , and you only install a 15amp breaker, art. 230.79 (A) says this is allowed.
Question: why would you have to have a main breaker to protect the panel ?
If you have a switch gear that says , can be used as service equipment when no more than 6 switches are installed, and you need only to supply a 15 amp load with a 15 amp breaker or if not where then would the protection for the gear be, as you have said about the panel.
Don, member #4,
