Service drop technique
svaurez
California
Is there a standard technique when connecting the bare utility neutral to the service mast insulator?
Do I pull the entire neutral through the insulator or do I split the conductor up and only pull a few strands through?
How many times do I wrap the conductor around itself?
Any wrong way to do this?
[ April 28, 2004, 09:39 PM: Message edited by: svaurez ]
Re: Service drop technique
Forget about the pre-form.
HERE is a wedge clamp. It's most commonly used for this application.
As Scott suggests, your utility normally would/should do this.
I edited the link to work now.
www.halexco.com is their homepage
[ April 28, 2004, 10:28 PM: Message edited by: luke warmwater ]
Is that wedge clamp for service entrance cable?
If a 2" rigid riser is used what type of fitting do you attach to the mast for the neutral to attach to?
[ April 28, 2004, 10:35 PM: Message edited by: svaurez ]
No, it's for the service neutral
click on the above halexco link. Then click 'electrical products', then '(SE)', then 'adjustable wireholder', then item #60525
Thanks.Just trying to learn the mechanical aspect of the service drop.
Sorry to be so annoying,but how would the neutral connect to this fitting?
Is there a standard method the utility uses?
This is what connects' to the riser pipe:
And this is used when the riser doesn't go above the roof:
And this is what most utility's use to connect the drop cable to the clamp;
And this is what most use to reconnect the service drop to the service entrance cable on a service upgrade:
[ April 29, 2004, 12:37 AM: Message edited by: hurk27 ]
