2005 NEC..... I thought I had read somewhere that a meter can with no means of OCPD and no disconnect IS NOT considered service entrance equipment. Around here it is VERY common to have a simple meter can ( no disconnect ) on the exterior of the house with a panel board on the wall opposite of the meter can, panel board has the main fused disconnect. 702.8 requires signage on the service entrance equipment, in this case that would be the panel board and not the meter can, correct?? Is there a code section that I can reference?
