stjohnbarleycorn
When using the service factor on a motor. if the service factor is 1.15 or greater, you can use up to 125%. IF the motor has no nameplate and you use the tables, should you use the 1.15 multiplier or the 1.25. Is it different if you use the nameplate? thanks.
