MarkRobisonPE
New member
Utilities often give a service fault of 65,000 amps and the plan reviewers require this number be used for the service even though there is a drop in amps due to the service feeders. If you add motor contributions, the number is always over 65,000 amps, which requires heavier duty gear. Is is common to not include motor contributions at the service when the fault is arbitrarily givin as 65,000 amps?
